Sky InsuranceAH Fabrications
    Aug 2003
    Stock Boost on the 5000 Turbo
    Just wanted to know what the stock boost setting is on the 1988 5000 Turbo. Whats the max that the ECU will let you run, and whats the make that you can run safley.
    May 2004
    Calgary Alberta Canada
    7
    Re: Stock Boost on the 5000 Turbo
    I would think in my opinion that the boost is really already set at the max for the ecu,I know even just upgrading the waste gate spring up to a 1.8 bar will start to mask the stock ecu's operation,not to mention there are a few other mods that should be done when doing this mod so the car is realiable too.It sucks sitting on the side of the road.
    Mike.
