Badger5Monster Motorsport
    Jan 2006
    Eire
    30
    1992 2.0E 100/A6 Avant - Autocheck
    I have an infuriating problem with the Autocheck on my car. The bulb failure light is almost constantly on. I have checked, and cleaned, all connections that I can find, with no success. I do not own a Bently manual for this car, but my 90 20v Bently manual shows some form of control box at each end of the wiring loom. I have searched all over for these in the 100, but to no avail. Can anyone help. I live in Eire and the local dealers are of no help, they do not appear to have seen such things!
    100 A6 Avant
    MkI GTI Golf Ball Gear Knob
    MkI Polo Rubber Gear Lever Gaiter
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    See on your sig you say no electrics is that meaning no electric windows,fag lighter not working?.........Dash Lights all working?
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Jan 2006
    Eire
    30
    No Electrics means. No radio, aerial or speakers, and all of the wiring removed. No electric windows, and all of the wiring and switches removed, switched to manual. Autocheck removed. Electrical diff controls removed, switched to cables. Light switch on column removed, VW rotary switch on dash. Indicator switch replaced with Saab switch. Wiper switch replaced with Saab switch. Dip switch on floor. Ignition by switch and push button. Steering wheel replaced with Saab 99 Turbo Momo wheel, separate horn button. Interior lights removed. All unused wiring looms removed. Of course the cigarette lighter is removed! Total weight savings approx 25 kg. Plus simpler wiring and maintenance.
    All other electrical systems, which should work, do work.
    100 A6 Avant
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    You got pics?
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
