AH FabricationsSky Insurance
Results 1 to 7 of 7
    May 2006
    cumbria UK
    Audi coupe v6 ecu location?
    anyone have any ideas where it is located? need to find a code on the box before i can order a chip. cheers
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: Audi coupe v6 ecu location?
    Should be located at the back of the Glove box ...if you look under the glove box you should see it there
    May 2006
    cumbria UK
    do i have to take the glove box out? there is a small box aprox 3 inch by 2 when i opened it it was like a resistor is that it?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    ECU LOOKS LIKE
    Taking the glove box out does make easier sometimes
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    May 2006
    cumbria UK
    cheers mate, thanks for the help.
    May 2006
    cumbria UK
    I checked behind the glove box, and the Ecu wasnt there, i asked a mechanic aswell. Any one have any ideas? ta
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    it will be there remove the passenger side trim under the glovebox and the glovebox itself, the ECU is sort of wedged really tight up against the bulkhead just above the carpet line. Pull the four plugs on the ECU and slide it out of the steel bracket. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
