it will be there remove the passenger side trim under the glovebox and the glovebox itself, the ECU is sort of wedged really tight up against the bulkhead just above the carpet line. Pull the four plugs on the ECU and slide it out of the steel bracket. /ubbthreads/images/graemlins/beerchug.gif
