EM TuningVolks Autos
    imported_muscle750
    no brake pedal Audi 100
    My Mother in laws car last night been driven when the brake pedal went to the floor with the pressure light flashing, the pedal is still going to the floor either with the engine running or not, how do i discover wether the accumulators shot or is it the seals in the master cylinder, there are no signs of any leaks anywhere and the fliud levels havent dropped. If the seals go in the master cylinder will the pressure warninglight still flash?
    Oct 2005
    South Wales
    155
    Re: no brake pedal Audi 100
    I don't know the 100 cars, but sounds like the system on the coupes, so have a look here:http://www.20v.org/brakprob.htm
    Where they refer to pentosin, it's a US brand of hydraulic mineral oil.
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    what year is your 100?
    The 1992 - 1994 used a normal vacuum assisted booster, the previous generation C3 shape used the power steering pump to get brake assist.
    Your problem sounds more like the seals have gone in the master cylinder. The assistance failing would not cause the pedal to go all the way down to the floor.
    Jun 2006
    7
    bleed nipples on calipers shot???
