AH FabricationsEM Tuning
Results 1 to 7 of 7
    Oct 2005
    coventry
    24
    Rear washer pump
    Can anyone please point me in the rigtht direction in looking for the rear washer pump in a '94 coupe? Mines not working and i'd like to minimise the number of interior panels I remove looking for it
    Andy
    Oct 2005
    Essex, UK
    1,222
    Re: Rear washer pump
    In my 93 avant, it was in the boot, in a side panel that opened on the drivers side! Not sure if its the same for a coupe!
    Oct 2005
    coventry
    24
    I know the washer fluid bottle is there but haven't noticed the pump. I'll go and check a bit later
    Oct 2005
    coventry
    24
    Found it, hadn't realised the pump was attached to the washer bottle. a quick test with a multimeter confirmed that power was still getting to the pump when the switch was activated so i set about removing the bottle and pump, surprisingly awquad especialy with the bottle full.
    Thats done now except for the pipe running up to the jet, how does this disconnect? I don't want to damage anything else taking it off
    Oct 2005
    Essex, UK
    1,222
    Glad you found it!
    Never removed the pipe myself, had a specialist replace that for me when I first got the car (Only had to pay for the rubber then), so wasn't worth messing around with!
    Own a A4 instead now though, so couldn't even go check. Sorry & good luck
    Oct 2005
    coventry
    24
    no worries, turns out to just be a push fit both into the pipe and the bottle, and e-bay found me a replacement pump for a very good price so it should all be sorted in a few days
    Oct 2005
    Essex, UK
    1,222
    Now that is good news!
