AH FabricationsChris Nott
Results 1 to 10 of 10
Thread: Usual hunting
    robonmac's Avatar
    Jan 2006
    Stockport
    76
    Usual hunting
    I know it's a fairly common topic but seeing as i'm new to this forum(but not Audi's) can anyone tell me what is the most common cause of hunting(between 900-1100Revs) on a coupe 2.0 16v 1993,and also how to buy a very cheap exhaust(middle and rear)for the same.
    I say cheap 'cos i'm running this car on a shoestring,well i might as well have an Audi on the cheap as opposed to say a ford?
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: Usual hunting
    The idle hunting problem is probably from the Idle Stabiliser Valve (ISV). You can try clean it with carb cleaner which may work for a while, but will ultimately need to be replaced.
    Exhausts... I could give you numbers for repair shops in South Africa if you like... :-)
    By The Hole in the Wall, Kent, U. K. (The 1st Hole in the Wall not the International one!)
    125
    Re: Usual hunting
    Believe it or not this can sometimes be caused by low or dirty oil
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Usual hunting
    I would check all vacuum hoses first if there is air getting drawn in this will cause this to happen........
    Exhaust
    http://www.cats-direct-shop.co.uk/ex...hp?recordID=94
    Check this one to be sure as this is sallon estate they say?
    ..Steve
    robonmac's Avatar
    Jan 2006
    Stockport
    76
    Re: Usual hunting
    Thanks for the exhaust tip,their prices really are very good indeed.
    My only note of concern was the omission of a coupe 16v variant,they have 2.0i with cats and 2.0e 's but no 16valvers.
    Now then, can i put a coupe 2.0i cat exhaust(obviously 8v) on a 2.0 16v, they state that this exhaust has a bore of 50.5mm.If you look at the 80 saloon/estate version (as in your link) with the 2.0i 16v cat exhaust it claims that it has a bore of 55.5mm,now if that is the case then an exhaust for the coupe 2.2/2.3 with a cat has a bore of 55.5mm then surely it will fit a 1993 coupe 2.0i 16v because the measurements are the same(length of pipe round axles and the like) AARRGGHH!!!!
    I'm going mad someone put me out of my misery.
    gags100's Avatar
    Aug 2003
    Tauranga, New Zealand
    44
    Re: Usual hunting
    you can buy a full stainless and get rid of the cat for 350 ish from longlife in Leeds
    robonmac's Avatar
    Jan 2006
    Stockport
    76
    Re: Usual hunting and cheap exhausts
    Yeh,i've had a rough quote for 319,but as mentioned before i'm skint so until i can afford one i need to get a cheapo steel one to keep me on the road.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Maybe try these guys out
    http://www.exhaustshack.co.uk/?source=googleadwords
    If you are unsure just go under the car and get an idea of the bends and size of the exhaust
    Steve
    Oct 2005
    South Wales
    155
    I'd say your logic is sound - re the 2.3 exhaust, but I would expect there to be a difference at the front end. i.e the downpipes might finish in a different place so you might need to shorten /extend a pipe, to get it to fit your 16v. I heard of someone who asked their main dealer for the price. It was stupidly expensive, so the guy says 'you will never get anyone to pay that for it, these cars are all 12+ years old' , the dealer gave him a much better price to get the stock shifted.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Good point Scotty........i did the same for my car at the dealers and got them to match VAG.com
