If the set up is the same as an 80, you don't even need to change the pin. If you
remove one of the rear facing bolts from a hinge, there may be a 12mm hex hole, through an 'insert' in the hinge. These
insert are threaded, so you can use them to alter the position of the hinge(s). You need to slacken the side facing bolts as well to allow movement and support the door. That's if it has the 80 style hinges
