Sky InsuranceEM Tuning
    gags100's Avatar
    Aug 2003
    Tauranga, New Zealand
    44
    audi 100 ,80 ,90
    Could someone with one of these models please tell me the part number of the battery that goes in the key fob, that lights the little bulb up. Have tried every where but they wont rip open the packets to check. hope someone can help
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: audi 100 ,80 ,90
    standard watch type battery's (4 of them), any camera shop should be able to match them up..
    gags100's Avatar
    Aug 2003
    44
    this only has place for 1 battery or 2 back to back
    audi5e's Avatar
    Jun 2004
    809
    my C4 was built in SA and fitted with a different alarm system, so I suppose that's why the battery's are different? (we need to be able to power the flame thrower...)
    atc
    Nov 2005
    Essex, UK
    105
    The battery in my 80 key is a Varta V 625 U. If you have a Maplin electronics near you they would be the best people to speak to as they have a conversion chart to match that battery make to one they have in stock (I used to work for them.)
    Remember when fitting hold the battery carefully from the sides not top and bottom, as it is possible to disscharge the battery by doing so.
    gags100's Avatar
    Aug 2003
    44
    Thanks very much, this is the correct one. very much appreciated
