Badger5Volks Autos
    Nov 2005
    Essex, UK
    90 Quattro (1988) rear dampnes
    Hello. First post, forum looks great.
    My 90 quattro needs new rear shocks, but the Haynes book gives no info on removing them.
    All it shows is the 80's non-independent suspension.
    I would be interested to hear from anybody that has done it themselves. How easy is it, are there any difficult bolts, can things go very wrong if the suspension arms are allowed to drop too far?
    Aside. The bloody heater blower. Absolutely nothing like the one fitted to the 80, or shown in the Haynes book. I can't get the fan out without removing ducting to the passenger side vent, and cant remove that without removing whole dash. It's driving me crazy with it's rattleing and churning. And only works at top speed.
    Cheers for any helpful advice.
    David
    28v6
    Re: 90 Quattro (1988) rear dampnes
    The Top speed thingy... maybe the resistor in the switch itself, a common fault on both 80s & 90s. try blagging a switch fae yer local scrappies then replace and see if it works at low speeds...
    Oct 2005
    South Wales
    155
    I recently removed the blower from a 90, should come out by twisting then pulling down.
    I changed shocks on a quattro, 13 years ago though so can't remember much. I know the hubs are early Audi 100 items,
    and the ball joints are the taper type. I guess if you pulled the wishbones down too far, you could damage the rubber bushes. Also my cv splines had been loctited, but I think this was dropped for 88> cars (mine was 87)
