EM TuningAH Fabrications
Results 1 to 8 of 8
Thread: Buying a coupe
    Oct 2005
    coventry
    24
    Buying a coupe
    Right hi all,
    basicaly i went to look at a 94 2.0 16v coupe at the weekend, just over
    80000miles, anyway it was a really nice car and i was close to buying it but i
    just had a few niggling doubts that stopped me, so hopefully you guys can send
    me one way or another.
    first off, the right rear shock absorber made a lot of noise initially squeeking
    whenever the car was moved but after a few mins this stopped and it didn't make
    a sound again...any ideas? should i be worried?
    second both doors seemed to droop very slightly, just enough that they banged a
    bit when shutting as the latch was a bit low when hitting the pin in the door
    frame, there was no sign of any accident damage or repairs and i think the car
    was otherwise very sturdy so i think the hinges were possibly a bit
    loose...easyily fixed or a more serious problem?
    thirdly the clutch had quite a late bite point, it wasn't slipping so it's not
    neccisarily on it's last legs but could anyone give me an idea of the cost of a
    replacement just in case
    finaly the dealer indicated there might be a problem with the relay for the rear
    wiper since it was difficult to switch off...any ideas?
    any help you can give would be greatly appreciated and hopefully i can go back
    for it this weekend
    Andy
    Oct 2005
    Swansea
    Re: Buying a coupe
    Hi , I have the same model , with regards to the doors :- the Coupe has larger heavy doors than the saloon but use the same hinges ,the extra weight tends to wear the hinges quicker therefore its just a case of popping down your friendly breakers and getting a pair of saloon hinges from anything as far back as a 1988 model ( any engine size ,mine came off a 1989 1.8cc saloon ) ., you might get away with just fitting the door part of the hinge and leave the post part alone as I did . I painted mine white to match the rest of the car then heavily greased them to discuise any paint colour variation to the rest of the car . They work a treat and feel as new to close with that ' quality clunk 'sound., hope this helps , cheers.
    DaveACQ20v's Avatar
    Nov 2004
    UK south west
    429
    Re: Buying a coupe
    Hi Andy, are you sure its the shocker squeaking? my guess is the brake is binding on slightly. Be interested to hear what the problem is for the rear wiper, coz mine does the same! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2005
    coventry
    24
    Re: Buying a coupe
    cheers Aggy, thats the sort of answer i was hoping for with regards the doors.
    Dave, no i'm not certain it was the shock but i'll look into it more closely if it happens again. as for the rear wiper i had a look on gsf car parts website and the wiper relay didn't seem to expensive so if it looks easy enough to change i might just buy one and try it
    anyway i'm picking the car up this afternoon so i'll let you know
    Andy
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: Buying a coupe
    Dave more than likley relay switch with the wipers...tell tail sign is when the intermitent wiper goes tree time inside of two or just gives up working
    Oct 2005
    South Wales
    155
    Re: Buying a coupe
    Regarding the doors, there is quite a lot of adjustment available at the hinges. replacement hinges should not be necessary.
    I don't mean to patronise, but the wipers are turned off same way they turned on - push the stalk forward. I only say this coz it caught me out when I did not know!
    Oct 2005
    coventry
    24
    Coupe Problems
    scotty, it's definately a physical problem with the wipers, it is difficult to turn on as well but even more so to turn off once you get it going
    Oct 2005
    South Wales
    155
    Re: Coupe Problems
    possibly the cables are breaking down
    where the hatch hinges. making it hard to get going. Then the increase in Amps welds the relay contacts together???
    Hows that for a wild stab in the dark!
