    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    194
    UrS4 auto rough running
    "Suzi" ( NAME OF THE CAR) has this optional extra
    normal service is fine, niiiice smoooooth ride.... THEN it feels like a switch is made in the engineroom dept, then it feels lumpy as your grany's custard
    feels like I lose a cylinder but when i give it a light dabble on the go faster pedal, it smooths itself out again
    Grizz mentioned the harmonic damper is tired so have a good replacement lined up being fitted in Sept along with the gearbox change.( 236000 miles on this one aint bad) ( multi function switch is playing up)....anyway....
    The other day sat at the lights I put the car into Neutral and the engine was rocking!! circa 800rpm definately felt like it wasnt firing on all 5 pots or maybe it was but missfiring badly.
    I had the idle position sensor changed recently because the 1 already there had a few codes on vagcom pointing to it ( still got the old one)
    my vagcom doesnt like Suzi so wont work because its not a few hundred quid genuine lead
    any suggestions what else it could be please?
    what would the symptoms be on a dying coil pack ? ( I have had changed 1 or 2 the previous times I have owned the car)
    would the harmonic damper feel like its lost a cylinder when its worn out?
    could it be the MAF?
    normally Suzi is quiet quick for an ole girl but when this sensor/ switch thing does its thing, She is slow to pick up, feels lumpy and cant be arsed or is that me ? lol
    in fact the sensation is like driving a manual car too slow for the gear your in, jerky progress but when i give it more revs its smooths itself out but acceleration isnt as hard as it should be regardless of speed.Even at motorway speeds all will be well then suddenly this shuddering sensation kicks in and its down on power as well, stamp on the throttle and it will smooth itself out again!
    99% of the time the car is as it should be and pulls really well, other times when She's rockin' acceleration is lethargic to say the least..
    any suggestions please? i dont think its mechanically sourced otherwise it would be doing this all the time
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    Jun 2011
    Great Melton Norfolk
    1,340
    which Audi is it? Have the injectors been cleaned?
  1. Rough Running
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2009, 17:39
  2. s3 210 bhp rough running
    By amorgan in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2009, 19:40
  3. Rough running
    By j4jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2006, 17:54
  4. hesitation and rough running
    By imported_scrupes in forum General Technical / How To
    Last Post: 30th August 2004, 16:35
  5. Rough Running Audi 80
    By DONK in forum Classic Audi Forum
    Last Post: 4th March 2004, 11:48
