Chris NottBadger5
    Jun 2012
    Newly purchased '93 100E Avant - a couple of questions
    My cheap estate has already turned out to be absolutely brilliant and is getting far more use than expected. However, there are a couple of things I need a bit og guidance on.
    1. Auto-check system.
    It seems to work fine in that it lights up and says OK in bright orange (and I'm getting an intermittent brake pad wear warning which I'll investigate at weekend). However, the fuel warning never seems to come on. I ran it down until the needle was edging off the red and into the black (I like to know where I am with fuel guages) but I never got the warning light. At what point should it come on and how long have I got when it does?
    2. Timing belt. It was done a couple of years ago but I'm going to do it again for peace of mind. Does the tensioner need to be changed at the same time?
    Jun 2011
    Great Melton Norfolk
    1,356
    best to change tensioner for peace of mind, cheaper to do it now when its apart than wait for it to seize up .
    No idea about the fuel warning light though.
    Aug 2010
    1,540
    hi keithyboy,
    if you want tech advice and interest in your questions heres the classic audi forum.
    Classic Audi - Powered by vBulletin
    people arnt really interested in pre "a" series audis on here, which is a shame as they are far superior to modern audis.
    my 100.....
    2.8 "aah" quattro.
    what engine is yours?
    my fuel warning doesnt seem to come on until the guage doesnt even move when you put the ignition on. ive done maybe 5 miles in this state before the fuel light finally came on. then filled up at the nearest station.
  1. Just Purchased A A4 Avant And Given It A Good Clean! What You Think Guys.
    By sam_a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th April 2008, 13:37
  2. Looking to purchase an S4 Avant
    By Maxxy_Priest in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2006, 08:42
  3. Couple of questions about my B5 S4 Avant......
    By arS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2006, 17:12
  4. Audi 100E Avant Automatic
    By badger81mini in forum General Technical / How To
    Last Post: 15th June 2004, 13:17
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
