AH FabricationsEM Tuning
    Oct 2011
    How do I stop my front shocks bumping?!
    Hi all
    Hope somebody resourceful can help me on this one! A couple of months ago I was doing some, shall we say, "vigorous" driving in my '95 Cabriolet when all of a sudden a loud knocking noise started up from the front of the car. It's especially bad under hard acceleration in 1st and 2nd. This rang a bell with a similar problem I had with an old 80 TDi I used to have, and my stomach just fell - I could never work out what was wrong with the 80 either, and scrapped the bloody thing in the end!
    Anyway, the main symptom is the massive half-inch gaps visible between the front suspension top cups and the chassis, when you look under the bonnet. With the car off the ground and the wheel off, you can yank the hub up and down and bump and rattle the top mounts around in their sockets, which I'm assuming wasn't a design feature!
    So I replaced the rubber strut mounts and even the steel spring cups with new ones, reassembled it all nice and tight and the gap is still there, bump bump bump. The maddening thing is that it's a simple setup assembled perfectly with all brand new parts and still does it! Does anyone know which part has failed? It's driving me nuts - I can strip and rebuild an engine but I can't seem to fix a simple rubber mount!
    Aug 2010
    1,540
    Quote Originally Posted by whizzo View Post
    this is normal. not your problem. look elsewhere.
    check ball joints, engine mounts, make sure the shocks arnt moving around in the legs (the screw on tops of the legs are tight). wishbone bushes. etc
  1. Any ideas how to stop my front wipers from juddering??
    By robbie5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2008, 13:55
  2. Front shock removal
    By clarko in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 22:48
  3. Replies: 1
    Last Post: 8th April 2005, 09:43
  4. How do I stop squeaky rear brakes????
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st March 2005, 19:04
  5. How do i remove the front and rear bumpers
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 16:37
