I
imported_scooters
Hi there,
I've got a bit of a problem with my oil pressure light on a 2.6 80 Avant (1994). Basically, once in a while, the oil pressure light will light up, beep 3 times and then go out. This is usually followed by another warning about 3 mins later. This usually happens about 20 mins into a journey then doesn't happen again. Oil Pressure is fine (checked in service last week) and the oil level is correct (not overfilled either).
Has anyone else had this happen to them??? - thinking that it may be the oil pump perhaps which is on its way out but not sure. If it is, is this easy to fit?
In addition to this, my reverse lights have just packed up. as there are two lights, i have discounted both bulbs going so am presuming that a wire is spilt between the boot and car. Is this easy to fix??
Many thanks in advance for any advice received
