Volks AutosAH Fabrications
    May 2003
    audi 90 wont idel
    My 1990 90 wont idel and is hard to start , but if you get it going it runs just fine as long as you keep your foot on the gas any one know what it could be, was running fine before I replaced air filter, plugs distributer cap and roater, also replaced hose that conects ike boot to idel control valve. after it starts it you let it die by not holding gas on it will not start again unless you let it sit for an hour. will not start without pushing on gas. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Aug 2003
    Johannesburg, South Africa
    Re: audi 90 wont idel
    Hi George, It would help if you can give us any info on what engine you have. However, it sounds like you might have a vacume leak. Check the vacume pipes and secure them with hose-clamps. Also check if you have replaced the rotor-arm correctly and check the ignition timing afterwards. If this does not help you could also check the electrical components.
    28v6
    Too Many cars... not enough hours in the day, My Friend!! [img]/ubbthreads/images/graemlins/goofy.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img] [img]/ubbthreads/images/graemlins/****_you.gif[/img]
    Regards
    Dave M
    Ram
    Ram's Avatar
    New Jersey, USA
    83
    Check the Idle stabilisation valve and the Air flow meter!
    Best wishes,
    Ram
    Dec 2003
    Colorado Springs, CO
    could it be timing?
    Jan 2004
    Connecticut, USA
    sounds like its the timing
