Chris NottSky Insurance
Results 1 to 10 of 10
Thread: Kjet conversion
    Kjet conversion
    Alright chaps... Im a bit of a noob here so bear with me. Ive just had the AA out to deal with my dodgy 2B carb, which desperately needs replacing... so I thought [img]/ubbthreads/images/graemlins/swear.gif[/img] it, I might as well bin the carb engine as its past its sell by date really. Question is, how difficult is it going to be to change the engine to a kjet equipped engine? The fuel system looks identicaly to the golf engine, the only difference I can see is the fact that the audi doesnt have a lift pump, its gravity fed IIRC. Any suggestions as to parts I will need for the conversion, and any areas I should be particularly pay attention to? The cars a 1982 80 1.6 GL FYI!! Thanks guys, appreciated [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: Kjet conversion
    There will be a few complacation doing that ,i take it you really like your car as the amount of money that will cost to do you could probably pick up a good Audi 90 or 80 with Fuel Injection
    Ready to drive
    http://search.ebay.co.uk/80_Audi_W0QQsof...ntrypageZsearch
    Check Link out
    Re: Kjet conversion
    They are all the newer shaped ones. Mines a mk2. TBH I cant see the complications, Kjet involves hardly any wiring, and will fit, as the 1.8 models used the same fuel injection
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: Kjet conversion
    If you use the original K-Jetronic, then you would need a high pressure fuel pump (around 3.5 - 4 bar pressure and above a certain flow rate), as well as the fuel distributor/air metering unit. Obviously you would also need to change the whole inlet manifold/throttle assembly to accomodate this system. You may also need a different cylinder head, depending of whether or not yours can accomodate the injectors?
    (there may also be complications with compression ratio's???)
    If you are planning on using the later KE-Jetronic or KEIII-Jetronic, then you are going to need the computers that control the whole setup, all the sensors as well as a complete ignition system, as both these systems are controlled by the ECU from signals received from the various sensors.
    Only the old K-Jetronic system is completely mechanical.
    My own advice to you is listen to Rev-head, and rather get yourself a later car that already has injection! (That is very good advice!!!)
    Personally I would rather saw off my head with a teaspoon than attempt what you are suggesting.... [img]/ubbthreads/images/graemlins/lol.gif[/img]
    Re: Kjet conversion
    Point taken.... but these cars arent very common nowadays, and this ones in pretty mint condition. Getting a later one would defeat the object somewhat. I would be going for the completely mechanical system as found in the mk1/2 golfs. The parts I have gathered that I will need are: Kjet main fuel pump and fuel lines, Mk1 Golf inlet manifold/throttle body. MK1 Metering head/fuel distributor, braided fuel lines/injectors, WUR, Air box, Cylinder head + cam, Engine wiring loom?
    Was having a look at the scrappy today and found a mk1 cabby with all of the above. Have you guys got any idea how the kjetted audi's mounted the fuel pump?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: Kjet conversion
    [ QUOTE ]
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/cry.gif[/img] [img]/ubbthreads/images/graemlins/cry.gif[/img] [img]/ubbthreads/images/graemlins/cry.gif[/img]
    audi5e's Avatar
    Jun 2004
    809
    Re: Kjet conversion
    The old K-Jetronic pump was mounted just next to the fuel tank. There was an inline filter between the tank and the pump. This was in addition to the large metal filter under the bonnet.
    audi5e's Avatar
    Jun 2004
    809
    Re: Kjet conversion
    You shouldn't need a wiring loom as a proper K-Jetronic is completely mechanical.
    seabass's Avatar
    Jan 2005
    Edinburgh, Scotland
    Re: Kjet conversion
    [ QUOTE ]
    [/ QUOTE ]
    Not striclty true matey.. Cold start injector and warm up regulator require some wiring....
    JC
    audi5e's Avatar
    Jun 2004
    809
    Re: Kjet conversion
    apologies, forgot about those two items... :-))
    I was so busy picturing the sensors all over the KEIII system.
    And thinking about my old Audi, that also had a controller unit for the ignition side. Though I am not sure if that also controlled the warm up stage of the fuel??
