AH FabricationsBadger5
    imported_Vinnie
    Oil Pump 5 cylinder Engine
    New one for you!
    Want to put in a new pump on this 5000 mile engine, more for saftey sake, because original owner re-fitted his when block rebuilt, and even though he swears its fine I thought that while the engines out and everythings accessible I would replace as a precaution!
    That was until I found that no-one does a pattern replacement part ( and I mean no-one) and even though the good old Haynes manual says you can replace the two ring gears you cant source them!!!
    Well-actually someone does sell them-yep, AUDI, and guess how much they want? Ł195 + vat!!
    There has got to be a cheaper way, any ideas, how about uprated ones????
    Please someone give me some hope!This is totally doing my swede in!!!!
    Vinnie [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    Re: Oil Pump 5 cylinder Engine
    Hi, is the engine diesel or petrol?
    imported_Vinnie
    Sorry, I forgot to include more info, I put loads on my other Question ((90Quattro Engine I.D) that I plain Forgot!!!!
    The engine in question is the 2.2 K.V 5 cylinder Normally aspirated! ( 1987)
    Regards
    Vinnie
