AH FabricationsVolks Autos
    imported_SoVodka
    temp light 4000cs
    Hi all
    The water/coolant light in my 4000cs flashes when i start it up in the morning and its cold and also when i take turns with enough velocity. I have plenty of oil, the engine temp is a different read out and its fine, oil temp is great, and ive checked the coolant tank which is full if not nearly(its where its suppost to be). Is this some kind of sensor glitch? [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: temp light 4000cs
    By the way you say the light comes on when takening corners means its maybe not faulty have you checked your power steering fluid,are you sure of the markers on the exspansion tank min and max ??
    imported_SoVodka
    ill check the levels agian to make sure, oh does anybody know a good german car magazine to get a subscription for?
