fog light probs 89 coupe quattro uk
burnsey
hi, i need advice,
i have owned my 89 coupe quattro for about 3 weeks and cannot get my back or front fog lights to function. /ubbthreads/images/graemlins/mad.gif
the fuse / bulbs and relay are ok and i am trying it with the lights on main beam.
now for the weird bit /ubbthreads/images/graemlins/crazy.gif
on the buttons they illuminate as normal, when you select either of them the blue / green warning triangle on the switch flickers for a second then nothing.
i am stumped /ubbthreads/images/graemlins/confused.gif, the rear lights aren't attached to the tailgate so it's not the wire from car to bootlid
PLEASE HELP as crap weather imminant
PS happy xmas
It sounds if you have dogdy fog light switch
To make sure when lights are on main beam take the switchs out (they just pull out gently) get a test light nothing fancy the ones you get on small screwdrivers make sure power is going to switch ,if it is it will be probably be the switch faulty
Back lights not connected to fog light if they were on every time you switched the lights on and you would tell by the number of people giving you the evils as they drive pass /ubbthreads/images/graemlins/grin.gif
Hope this helps
Tell us how you get on
