W8 PerformanceKowalski
Results 1 to 7 of 7
    Oct 2010
    Post Thanks / Like
    Problem with hunting Audi 80 1.9 TDI 1994
    Hi.
    I have cut the blue & white vehicle speed sensor wire on my audi 1.9 tdi.
    Driving much improved, but still hunting on idle.
    Any suggestions?
    Oct 2010
    Post Thanks / Like
    Can someone please help.
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    what engine code is this? 1z? is there a reference injector on this? two wires going to one of the injectors? check the resistance thru it? is it open circuit?
    Sep 2010
    10
    Post Thanks / Like
    hi, had the filter on the end of the fuel tank sensor gunged up on my 80 tdi and it ran strange, question for you where is this blue/white speed sensor wire as i have a strange prob with my 80tdi ( see my post)
    Rich Hall
    Apr 2011
    Norwalk
    10
    Post Thanks / Like
    I have also Audi 80 1.9 TDI.It was in a very good condition,and is still working very well, during 2 years of using it we had no problems with the car.The engine works very well and is really very economic.Also very importatnt thing is that it doesn`t lose too much value after years..I think,two wires going to one of the injector.So,first you will check injector.
    Sep 2009
    15
    Post Thanks / Like
    VAG COM it. It will tell you want's wrong and hopefully remove some of the guess work for you.
    Sep 2009
    15
    Post Thanks / Like
    Plug it into VCDS and it will tell you what is wrong and save some guess work hopefully.
