VAG CheckForge Motorsport
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    Engine types and results from a Re-map!?
    Hi Chipped!
    I'm looking into a Re-map. You seem to be very competatively priced and have good feedback.
    My question is though, looking at various data i've trawled through via the internet etc the AMK engine and BAM engine are identical. Is the only difference the boost pressure upped a little to produce the 225Hp over the 210Hp for the AMK.?
    Why then is it not possible to see better results from a mapped AMK as the horsepower gains are more taking the 15Hp extra that the 225 has ontop of the say for arguements sake 40Hp.
    So in total the 225 would be capable of say 270Hp an increase of 45Hp.
    The AMK goes from 210 to 270 giving an increase of 60Hp.
    Am i on the right lines here or am i totally off the mark???
    G
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    12,881
    Post Thanks / Like
    G I'm sure I read somewhere that the reason that the newer S3s put out 225hp over the old 210hp was because of something to do with the valve timing being modified!
    FOR SALE
    - BAM connecting rods
    - 1.8T cams
    - K03 OEM Exhaust Mani from AEB head
    - 1.8T Water pump, only a year old. (5K miles)
    - OEM S3 back box complete with both bits of trim
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    Hmmm Could be.!!
    Wonder where i'd find this info out!??
    Audi??
    G
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    12,881
    Post Thanks / Like
    FOR SALE
    - 1.8T cams
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,303
    Post Thanks / Like
    Thanks for that but it's not what i'm after. I'm trying to find out what the differences are for certain between the AMK and the BAM.
    My car has VVTI as i've had it replaced. I think it's boost pressure, slightly more with the 225 BAM's. My above question still stands Chip can you answer them??
    G
