Sky InsuranceAH Fabrications
    Lord Bigfoot's Avatar
    May 2010
    Intermittent Radio Signal - 2005 A4 Cab - Please Help !
    Hello
    My radio signal keeps dropping out at random times
    The aerial is fitted to the car internally somewhere and I do not know where it is
    Anybody able to suggest where the aerial is so I can have a check for any loose wires etc ???
    cheers
    LBF
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Usually this is because the antenna wires travels through the boot lid hinge to the antenna module in the boot lid. So over time they weaken and break.
    You need to have someone scan the car for faults with VCDS (VAG COM) and see if there are any faults shown.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    as above, put radio on so you can hear it from the rear of the car, open the boot, have a play about with the left rubber boot, youll hear the radio come and go with your movements, the ariel will deffo be kinked/damaged, i pulled back the rubber and found the kink and cut it out and rejoined it, never been a problem since
    LOTS DONE, LOTS SPENT !!!!
