Monster MotorsportBadger5
Results 1 to 13 of 13
    fattiereturns's Avatar
    A4 2.0T Q
    May 2010
    Aberdeen
    41
    Audi Navigaton Plus
    Hi folks,
    recently got a 2007 a4 with the above double din sat-nav / radio. According to the user manual I should have TV, bluetooth, automatic ball scratcher - the lot!
    Can't see that it has TV, (not on the list of sources) can't see anything referring to bluetooth, (just get a "phone not installed" message) and am scratching nads the manual way. Is there a lower spec unit that probably falls under the same user manual?
    Also, as the map info on this unit is DVD ROM, I'm presuming there's no way to update it with speed camera information, or even the details of mobile cameras which are released weekly? If this is the case I'd more likely care to swap it out. Has anyone ever found a nice aftermarket double din which will do all the functions and integrate with the dash display and wheel controls? I had a nightmare with an older a4, with an aftermarket unit playing funnnies with the bose amplifiers in the speakers - are the newer bose systems still prone being picky about line deadening?
    What a rant eh?
    Cheer folks
    Pii
    Pii's Avatar
    London
    748
    The RNSE does not come standard with TV and BT. These are additional devices that can be linked with it.
    No speed camera too on the Audi Sat Nav and no input possibility that I know of.
    After market DD do not look OEM or work with the DIS but you can buy some steering wheel adapters that will work to a degree.
    Sadly the BOSE issue is ongoing so I have been recommended that changing an afrermarket unit would require chaging speakers also.
    Good luck!
    Apr 2010
    London
    22
    For speed cameras go here www.navpoint.co.uk
    2014 Audi A3 Sportback 2.0TDI (184) S-Line Quattro | Panther Black | Nappa Leather | Black Styling | Roof Rails | Comfort Pack | Tech Pack + Audi Connect | B&O Sound | Parking System Rear | Cruise Control | Interior Light Pack | LED Headlights | High Beam Assist | Door Mirrors Elec/Fold/Heat | Privacy Glass
    A4 2.0T Q
    May 2010
    Aberdeen
    41
    great stuff, thanks lads
    A4 2.0T Q
    May 2010
    Aberdeen
    41
    Quote Originally Posted by Pii View Post
    Good luck!
    My old A4 had bose system and I put together a couple of little adaptors with capacitors in-line as advised on some website somewhere...
    Anywhoo, they worked a treat and I happily ran a Kenwood BT / ipod unit for a year or so. The adaptors weren't the prettiest of things but served their purpose. Hopefully that would save me changing out the speakers?
    I've seen the pioneer navgates and they look like pretty slick once fitted with the right fascia adaptor to be honest...
    JohnS3's Avatar
    Oct 2004
    3,021
    The navPOInt software has just been launched.
    navPOInt - custom POIs for your Audi SatNav
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,591
    anybody tried that yet?
    I've had a Snooper S6 (Snooper EVO) for years and years but the speaker just went pop last winter so now it sounds like a Dalek.... so I've just ordered the Snooper Lynx which does the same thing, plugs into the same 12V hardwiring kit, etc... and does constant updates without needing a PC, including active mobile sites IF somebody else has spotted one... it DOES however need a Ł8pcm mobile contract
    LostBok/BahnStormer77
    JohnS3's Avatar
    Oct 2004
    3,021
    Yes I have it working. I like it as it's OEM with no wires and beeping things stuck on the dash. I drive with the RNSe set to 400m resolution and glance down occasionally to see if there are any cameras in my vicinity. Works well for me.
    BahnStormer
    Feb 2009
    Surrey
    2,591
    Ah - I've seen it now: no notification and only visible on the main screen, not the DIS.
    I'll stick to the dashboard one: no visible wires when fitted properly and only really beeps if you are exceed the speed limit.
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    I've got the same system with TV and phone in my A4, does anyone know how to get them working?
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by andyherd View Post
    What do you want to get working?
    Jan 2004
    York
    1,657
    Have a look on here KUFATEC GmbH & Co. KG - A4 - B7/8E
    Kufatec are expensive compared to some ebay adaptors.... but they work first time every time, and the cabling etc is usually OEM spec.
    MY15 8V S3 Sportback with options
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    Quote Originally Posted by JohnS3 View Post
    The TV and phone functions on my system, I'm guessing both nedd activation some how
    Quote Originally Posted by auroan View Post
