Sky InsuranceVolks Autos
Results 1 to 13 of 13
    Amir's Avatar
    75
    Audi A4 Avant "Big Install"
    Hey.. if you have followed my previous posts you will have seen me talking about weight issues as I had a sound install on it's way so here it is just lots of pictures to keep you busy for a few minutes .
    Amir's Avatar
    75
    Amir's Avatar
    75
    Amir's Avatar
    75
    Amir's Avatar
    75
    Amir's Avatar
    75
    PD Score = 146.7dB
    Peak = 148.1dB @ 39Hz
    40Hz = 148.0dB
    33Hz = 147.7dB
    25Hz = 146.3dB
    20Hz = 143.7dB
    dB Drag
    148.3dB @ 43Hz
    Scores taken with standard alternator and subs were stiff! Suspect this will break a 149-150db
    Now pictures to follow of the alternator install
    Amir's Avatar
    75
    had to trim the rear corner of the engine cover to make it fit and not chafe the cables
    you can just about see the big 3 earth cable on the top bolt hole, can't get much better than bolted to the alts chassis me thinks
    over 260 amps at 2krpm, 170ish on idle, not bad for a 210a unit
    still drops to 13v but with upwards of 300a draw (500-600 max amps) its not doing bad and the diesel doesn't flinch
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Bet it's pretty quiet
    Nice install, why are the subs pointing up as opposed to facing in the car out of interest?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Amir's Avatar
    75
    Not enough room, then you want back seats taking out and it's called a "Wall"
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,511
    The subs can in theory face any direction as bass can travel any direction IIRC
    I am glad to see the big 3 still being used.
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    Where the hells Fido going to sit now?
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Hi,
    your subs look amazing and must sound very nice!
    I am quite envious, coming from two ****ty evo cbr 12's in my A3 to nothing in my A4 avant.
    I was wondering, if i was to get something along those lines in my Audi A4 Avant, how much would a audio shop charge? Are we talking over 1,000?
    Is there any easy ''Clip on'' ''Clip off'' system used so the subs can be removed within a minute rather than tirelessly unscrewing each wire one by one etc as this is a problem i had in the A3, and that only had 3 wires i think. Live, Ground and RC..plus the two RCA's or whatever they are called!
    Sorry for thee lack of knowledge. I await your response!
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    to disconect the wires quickly, live and earth then i would recomend an anderson conector, its what the rac/aa have on there van that they use for jump starting other cars from so more than up to the job, as for the remote wire, a simple push on splade will do the job
    anderson connector:
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    fair does thats an impresive install, you using it for sound offs / spl compertitions or just to annoy next door?
