EM TuningAH Fabrications
    61
    Question Going to replace speakers - a few things to check please? (A4 B6 Cab)
    Hi all,
    Basically I am about to replace the speakers on my A4 B6 Cabriolet, but I would like to get a few things confirmed before I go and spend all that money.
    This is what I gathered from the internet.
    - Front and rear speakers are 6.5" (165mm)
    - Tweeters are 1" (25mm)
    - Crossovers are in the doorcards
    Now my questions are...
    - Are the above correct?
    - What is the maximum depth of front speakers can I fit? Or do I need an MDF ring to pad it out?
    - What is the maximum size of crossovers can I fit without modding?
    The headunit is a standard RNS-E, and speakers are not Bose, by the way.
    Thanks.
    Jun 2003
    World of my own
    9,813
    Yes your info is correct. You will need adapters, 2 x 18mm MDF rings per speaker, with a bigger 9mm MDF mounting ring behind to allow the rings to screw to the door using the original bolt holes. Just use the original speaker as a template and screw these to the 18mm rings. You'll also need some Dynamat to even out the inner doorskin to form a perfect seal as it's not completely flat. Depth is not a problem as you have 45mm with the rings plus there is a hole in the door skin for the magnet. There is plenty of room for a decent xover, and rewiring through the A pillar is almost impossible. You should also get some spare pop fasterners (approx 6 in total) as these are designed to break on removal:
    Alex Turner
    61
    Just what I needed!
    Words cannot express how much I appreciate your reply.
    Thanks a lot! :D
