JMB RetrofitsSky Insurance
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    S3 8L Replace door speaker Bose
    HI
    Worlds worst car mechanic so looking for a guide on replacing the front bose speaker as its blown
    Anyone have one - or describe the process ?
    Is the job relatively straight forward ?
    If you aint first you're last
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    set up email alert
    Jun 2003
    World of my own
    9,813
    First lower the window, then remove the 2 visible screws at the top on either end of the door card, remove the single screw inside the grab handle, push down the plastic cuff inside the grab handle and remove the 2 main screws behind it. Pull the whole door card straight up and out, but not too far as you need to unhinge the door release cable and unplug the wiring looms.
    Bose front speakers for an 8L are pretty rare on ebay but they do come up. Are you sure it's the speaker and not the amp, as the amp is more prone to failure, usually a dry solder joint on the PCB. If the tweeter still works OK then it's the speaker, but if the tweeter crackles as well then it's the amp as they both run off the same channel & wiring.
    Alex Turner
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    Thanks Andy
    I ordered the speaker earlier today from Audi (107) so I had best go and check the tweeter - although its ordered now ;(
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    Phew
    Tweeter seems fine
    Thanks again for the guide
