Chris NottBadger5
    imported_Pottsy
    A4 B6 door panel removal - help!
    Anyone taken these panels off? Can only find info on the B5....
    Started on the passenger door. Screw at bottom, screw under the armrest, wood trim off and 4 revealed screws out. Still as rigid as when all the screws in!
    Thanks in advance....
    imported_Yaseen
    Re: A4 B6 door panel removal - help!
    This is for the drivers side:
    "pull the bottom, outwards slowly working your way up
    You can see how the door panel hooks over the window sill. Once you pull the panel off your gonna need to unhook the cable for the handle release and the wiring plug"
    be VERY careful not to break any of the clips
    NOTE: The driver side has 7 screws so make sure you havent missed any
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_Pottsy
    Thanks! That's all I needed to do. Broke 1 clip on the passenger side and none on the drivers. Didn't seem to matter though.
    Sounds miles better with Focal Access's and my Alpine 7878 HU. Sub next!
    imported_Yaseen
    hope you amped the speakers and dynamatted as will make a big differnce
