Monster MotorsportVolks Autos
Results 1 to 17 of 17
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    S3 Satnav Plus and Ipod
    hey guys
    very new to this site so bear with me if i get things a little wrong
    this coming saturday im picking up my S3 on a 56 plate, as it stands its got the audi navigation plus system with bose and the 6 CD changer in the glove box
    now as i dont really do cds id like to change the cd multi changer to an ipod cable, now ive spoken to 2 different audi delaers and one said its about Ł300, the other about Ł30 so u may see my confusion!!
    does anyone know what i need to get an ipod working with the head unit and what the likely cost should be?
    cheers in advance
    Paolo
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    You may want to look at the Dension Gateway unit. It acts like a 6 disk CD changer, where you can have Playlists. Not as neat as the full Ipod, but you cant have the Audi AMI as your RNS-E wont support it. IMHO many people just use the SD slots as you will get track names etc. It will be the cheapest way, and the most functional.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    comc's Avatar
    VW-7 Audi-1
    Edinburgh
    49
    Paolo
    I have the RNS-E with bose, and i use the genuine audi Ipod adapter kit to hook up my iphone. The cable charges the ipod/iphone and also allows you to play through the CD changer function on the RNS-E, however you dont get any track info. That would certainly be your cheapest Audi option, which is probably closest to the Ł30 figure quoted by the dealer (although I suspect the kit will be a bit more than Ł30). There are many other makes on the market so check all options before buying.
    I am happy with the audi kit and got mine relatively cheap on ebay (Ł60) so check there from time to time.
    Just a word of caution....depending on when you bought your ipod.........apple altered the charging basis on later ipod/iphones from 12v to 5v which I think caused them to alter the charging pins.......therefore if you are planning to buy second hand make sure the cable in the kit is definitely suited to your age of ipod.
    2006 A4 Avant 2.0 TDI (140) S-Line
    Phantom Black
    Audi Phone Prep, Bose, retrofit RNS-E, rear Parking Sensors, rear Sunblinds, Canbus friendly LED sidelights
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    cheers guys
    humm looks like ill have to go down the SD card route as id like to know what track im playing
    do you know if there is a limit on what size card the RNS-E will recognise as ill need a couple of 32GB cards to fit all my music on
    Paolo
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    forget putting big cards in, the rns-e will only recognise 512 files
    have you thought about doing the aux in mod, did mine last week, works a treat for iphone, then you get to keep cd changer aswell
    LOTS DONE, LOTS SPENT !!!!
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    not heard of the aux in mod.... what is it and how does it work?
    how will that work with the ipod and tracks etc?
    Nov 2007
    485
    The RNS-E can only accept upto 2GB per slot.
    Quote Originally Posted by jungleman View Post
    cheers guys
    Paolo
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Quote Originally Posted by 1wheelonly View Post
    Would be interested in this as its what im looking at doing, does it use composite or component av cable?
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    neither, uses 3.5mm jack, aux in doesnt allow video in, youd need an interface for that
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    ahhh ive got you, so i guess that means you dont have the ability to charge the ipod whilst driving?
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Don't want to use phone jack want to use av tv inputs which I assume is the standard RCA or composite leads, but does the rns-e unit have av inputs built in or will i need an interface lead? Also where does the interface lead fit? Thanks
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    youll need one of these http://cgi.ebay.co.uk/AV-Multimedia-...item25588dfde2 it goes into the rear of the rns-e in the 32 pin connector, this is the one ive got but there are others around
    royjk's Avatar
    Apr 2008
    167
    Wrong you can use up to the maximum that you can get. The limitation is the amount of files not on the zize of the card
    A3 CABRIO S-Line 2.0 TDI DSG
    Liquid Blue-Blue Hood. Celtic Tunning Remap with E Motion -RNSE-Seperate DVD Player-100gb Portable Hard Drive-USB-Phone Prep-Exnon Adaptive Lights-Heated Seats-Lumber Support-Acoustic Parking-Light & Rain Sensors-Interior Light Pack-Storage Pack-Cruise Control-Folding Dipping Mirrors-Interior Auto Dipping Mirror-Bose-Hill Hold-SDS-FBMFSW - Alpine iPod Controller
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    WRONG ??????????? what does the above say ???????????????
    27,113
    Quote Originally Posted by royjk View Post
    Sorry but you are incorrect, there is a limitation on the MK1 RNS SD card use, you can use 4GB SD cards but it still has a file limitation, Wheelie is correct.
    RNS MK2 is almost limitless upto 32GB.
    Nov 2007
    485
    The 4GB SD (Not SDHC) are near impossible to source. I have only found one company who sells these still.
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    27,113
    I'll give you that, thats why I bought 4 lol.
