Volks AutosAH Fabrications
Results 1 to 9 of 9
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    WHICH IS BETTER ?? CONCERT or SYMPHONY ????
    quick question
    i have a concert head unit with Bose speakers
    is this the best setup in terms of quality
    if not, then what is and is it possible to do a simple retrofit
    also any tips on sound improvement are much appreciated
    thanks
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    They are identical except the symphony has a 6 CD onboard and the concert is single CD
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    ok - so no sound quality difference ??
    i sent you an email via your website - did you get it?
    about retro fitting sat nav with bluetooth and tv unlocked?
    Jun 2003
    World of my own
    9,813
    Exactly the same spec although the Symphony has more control over the sound. It has some hidden EQ settings and a middle control, the Concert only has Bass & Treble. Not that they do much with the flat EQ on the Bose system. If you want to liven up the sound a bit then snip the earth going to the Bose pin on the back of the HU. That will give you better control of the sound.
    Alex Turner
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    hi
    to pick up on this again
    exactly how will this improve the sound and whats the easyiest way of cutting this wire in terms of access - dont want to remove the HU inless needed
    thanks
    NOW FOR SALE
    Audi A4 Avant S-LINE 2.0 TDI
    BOSE - PARKING SENSORS front and rear - ANGEL REMAP to 183bhp
    LED NUMBER PLATE LIGHTS, HIDS, LED SIDE INDICATORS, LED SIDELIGHTS,19x9 BENTLEY'S, S4 345 MTEC Drilled/grooved Disks -35 on H&R SPRINGS, RS4 REAR ARB RS4 Grille FULL VCDS LED RNS-E DECTANE LED REAR LIGHTS
    TO DO:
    NOTHING - Am i finished really ??
    May 2009
    south yorkshire
    563
    i too would like to know how cutting the earth would do anything except render the bose amp dead
    Jun 2003
    World of my own
    9,813
    Render the Bose amp dead? Yes that's exactly what it does, which is why I recommend it!
    The Bose wire is purely an earth to the Bose pin on the HU which flattens the EQ of the HU i.e. no highs no lows it must be Bose. Whereas every other HU in the world has a smiley face EQ where you can adjust the Bass and treble and it actually changes the bass & treble, Bose don't really want you meddling with their muffled "sounds great in a lab" sound and would rather you listen to their settings as defined in the Bose amp. Snipping the earth going to the Bose pin just reverts the HU back to the EQ settings of a non Bose HU, so far more control over Bass & Treble. You can only access it by pulling the HU, all of a 5 minute job, just ensure you don't pull the HU out using the release keys, but remove the glovebox and push it from behind.
    Alex Turner
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Whats wrong with release keys Andy?
    Jun 2003
    World of my own
    9,813
    Nothing, sorry didn't make it clear. Use them to release the spring clips, but just don't pull on them to get the HU out as this can knacker the clips if the keys are properly engaged.
    Alex Turner
