Chris NottAH Fabrications
    imported_kris_tdi
    Concert Headunit
    Does the Concert headunit that comes in the b5 a4 have any pre outs on the back? i cant find my keys too check it, cheers.
    Jan 2004
    York
    1,657
    Re: Concert Headunit
    nope - unfortunately
    Jun 2003
    World of my own
    9,813
    Yes it does, all Audi head units have both front and rear pre-outs. The Bose programmed HU uses both of them to drive the Bose amps, and the non Bose just uses the rear pre-out for the rear speakers.
    They are on a non standard mini-ISO plug, but an adapter is available to convert to standard RCA's with remote on lead. Some HU's have an integrated plug with the CD changer and DIS loom connected to the same plug, but most have a single multicoloured plug that can be separated and the adapter slotted in without any cutting needed.
    You can also pick up the rear pre-outs and remote on from the rear amp bolted to the right rear speaker.
    Jan 2004
    York
    1,657
    My mistake I was thinking about it with out making any alterations or using adaptors
