EM TuningSky Insurance
    imported_Yaseen
    On a b5 fitting a HU question
    Does anyone know which wire is the ignition wire on a 96 a4? (to turn off the stereo completely when ignition off)
    Ive fitted a stereo which didnt come with a wiring plug so cut the audi loom and connected them up seperately- but cant work out which is the ignition wire so the stereo draws power all the time unless i remove the fuse from the fusebox which is a real pain.
    any advice?
    Jun 2003
    World of my own
    9,813
    Re: On a b5 fitting a HU question
    If you still have the Audi ISO plug that you cut off, you should be able to see how it is wired. The ignition on live is the 3 along from the ground (thick brown) wire.
    imported_Yaseen
    many thanks for the replies [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Will try both ideas- im pretty sure I left the iso plug in the HU bix so will try to find it.
