AH FabricationsBadger5
Results 1 to 8 of 8
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Canbus chorus/ concert
    Hi.
    Currently i have a chorusII headunit (according to vagcom)
    Is this canbus equipped?.
    If it is, would it be the same pin config as a concert II (from an a3 8p)
    ...i believe all concert II's run canbus?.
    Regards
    Callum
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes, pin for pin, so straight swap.
    If it is Chorus II it is CAN BUS.
    Jun 2003
    World of my own
    9,813
    Just ensure it's from an early 8P, as they moved from ISO to Quadlock connectors around 05
    Alex Turner
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Thanks guys.. just what i wanted to hear, its from a 2003 so should be lovely.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Hi,
    UI got the radio, all seems good, ill hopefully fit it at the weekend when i have a spare 5 minutes.
    Can anyone confirm if this is quadlock?
    Also, whats the square yellow connector?. as i think mine on the chorus is round.
    regards
    (sorry about the pic size)
    Jun 2003
    World of my own
    9,813
    No that's definately ISO. The yellow connector is the second antenna connection (ZF diversity switching lead using a Fakra connection).
    I think you can just ignore it as the standard round ISO connection handles the main FM/AM signal. The Fakra one only works if you have the antenna module in the rear, which you won't.
    Alex Turner
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Awesome. thanks again Andy.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yeah but it would be twice as big. ie double din if it was a quadlock concert.
    Quote Originally Posted by AndyMac View Post
