JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Oct 2009
    Question for those who have replaced front a3 8l speakers with aftermarket ones
    hi all, i would like to know how the quality of audio changed after replacing genuine speaker with aftermarket 13cm ones. What components did you replace with. maybe some of you have recommendations. Sorry for my english as i'm not english
    Jun 2003
    World of my own
    9,813
    Very little improvement to be honest. The speakers are severely compromised by both the flimsy door card they are attached t and the feeble 20w power that feeds them. If you want a decent improvement leave the speakers and install a stealth sub:
    http://www.dizzythedog.com/index.php...tealth_sub&a=0
    Alex Turner
    Oct 2009
    I have already placed 12" sub in the boot, but i want more sound in the front and installed pioneer p77mp headunit.
    Oct 2009
    to make thing more clear: at this time i have already installed HU pioneer p77mp, and pioneer 12" sub, and i'm going to install 13cm components in the front (sth like focal kit 130v1) and connect them to some good 2x100 rms amp, would the quality of sound change and would this be worth the spent money? an one more quoestion, is there any way i can fit in speakers than have 61mm mounting depth. reason i am asking is that i had unscrewed the door panel an added some 2cm thickness round metal thing on top of the bose speaker to simulate a speaker that has bigger mounting depth and it fitted perfectly, the door panel stood back in it's place well and the window was functioning ok.
    Oct 2009
    is there anyone who can advice?
    Jun 2003
    World of my own
    9,813
    The sound will still be severely compromised by the door card mounting and the fact the door card is loosely clipped to the door. It will be an improvement, but not huge.
    The 50mm depth restriction still applies, as this is also taking into acount the adapter ring you will need between the door card and the speaker. The stock speakers sit flush to the door card, a 5.25" unit will need either a flimsy plastic adapter or a proper MDF adapter which adds about 12mm to the available depth.
    Alex Turner
    Oct 2009
    Quote Originally Posted by AndyMac View Post
    So how was i able to add those extra 2 cm to the speaker, total mounting depth was 80mm and the door panel was ok on it's place??
    Jun 2003
    World of my own
    9,813
    Total mounting depth 80mm? How on earth do you work that out. The Bose speaker is not 60mm deep, nowhere near. Knock yourself out fit something deeper, I'm just telling you what the limitations are, I really don't want to argue about it.
    Alex Turner
