EM TuningVolks Autos
    KeepItTidy's Avatar
    Apr 2009
    RSA
    88
    S3 8P Bose components
    I've got Bose with the RNS-E.
    Just interested in what speakers/subs/amps are actually in the car.
    I think there is an 8'' sub?
    I have a really kick ass Rockford 8" HX2 which will probably perform better then the Audi one. Thinking about putting that in my car.
    any1 know if it will work?
    What is the power of the Bose amp?
    thanks
    Jun 2003
    World of my own
    9,813
    It's not the Bose sub that's the problem in the 8P, it's the flimsy plastic box it occupies that means you can't get decent bass from it. It really is no more than a biscuit tin:
    And it's only a 6" unit. It's driven by the main Bose amp which provides a feeble 100w peak, so about 50wrms, and it seems to be tuned to provide mid & low(ish) frequencies as with just the sub playing you can easily identify the song & hear the singing. This provides quite a hollow woolly result which is why I developed this solution:
    This is a custom 18mm MDF enclosure housing a JL Audio 6.5" 250wrms sub. It's then powered by an Alpine V12 amp hidden behind the rear speaker card and this is fed from the existing Bose wiring, so the only additional cable is a 40amp power cable straight to the battery.
    There's more info on the web site:
    http://www.dizzythedog.com/index.php...tealth_sub&a=1
    The result is quite a phenomenal transformation, clean punchy bass and lots of it enabling you to run the stock HU at minus 2 on the Bass setting which improves the sound from the cabin speakers as well. There's a couple of reviews on the web site.
    Alex Turner
    KeepItTidy's Avatar
    Apr 2009
    RSA
    88
    Awesome man! exactly what I needed!
    Thanks!!!!!!
    Boosting..
    Sep 2011
    South Africa
    Hi Andy,
    Can you give me details as to where I can buy such an enclosure for my 2007 8P S3. The problem is that I am all the way over in South Africa.
    Any assistance/Advice would be appreciated.
    Regards
    Solo
    Jun 2003
    World of my own
    9,813
    As far as I know I'm the only one who makes them. Can ship to SA but it would be about £55 P&P as it weighs 4Kg's for just the enclosure. You could source the sub & amp locally.
    Alex Turner
