Sky InsuranceChris Nott
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Will Bose from A4 fit A3?
    Just an example but would bose from another model Audi fit another?
    I fancy upgrading to Bose in my S3 and just curious if you can use another models Bose instead of A3 specific
    What else is required to install Bose or is it just plug and play and uses the existing wiring?
    Jun 2003
    World of my own
    9,813
    No you need an A3 Bose system, both the speakers and the sub are completely different in other models. Apart from obviously replacing all the speakers and the sub, you'll need to completely rewire the car, so not an easy process. You'll need to run the front speaker loom back to the boot, the rears back to the other side of th boot (drivers side)the sub loom & associated power and mount the amp. As a result you'll have a slightly better sounding system, so really not worth the expense or hassle. Far better to go aftermarket or install one of my stealth subs for a huge improvement.
    Alex Turner
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Cheers Andy.
    I was hoping that the Bose used the existing wiring
    Oh well, scrap that idea and I have just sold my Focal K2P's
