Monster MotorsportVolks Autos
    Jun 2004
    lincolnshire
    395
    12v ign?!!!!????
    well finally got around to removing the standard hu! with my pc9-404 absolute cr,ap!!!! 1st thing i had to do was swap the yellow with the red wire, only wire in the right plce was the earth, but only thing is that i cant find a 12 volt ignition! seemed kinda strange to me so i wondering if im doing somethin wrong as the only 12v ignition i could find is in the fuse box... any pearls of wisdom would be greatly appreciated
    cheers tony
    Jun 2003
    World of my own
    9,813
    Re: 12v ign?!!!!????
    Common problem with late A3's. They use the CAN-BUS to sense whether the ignition is on or not.
    You therefore need to wire in an ignition on feed.
    see
    Jun 2003
    World of my own
    9,813
    see this thread No ignition on?
    Jun 2004
    lincolnshire
    395
    cheers andy im doing something similar at the moment just so i could get it working. i will do wat you suggest as its much more professional than my job!
    cheers tony
