Chris NottAH Fabrications
    Sep 2003
    Bournemouth
    312
    RNS-D to RNS-E connectors required
    My factory fitted rns-d is playing up so i bought a rns-e but need some different conectors or adapter plug/leads leads.
    this is my old unit
    this is the new one.
    The connectors i need are for the gps receiver and the fm aerial, the quadlock should be fine but might need wires swapping. Where can i get the conectors/adapters in the UK?
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Dec 2008
    Blackpool and Watford
    133
    Ebay is your first point of call
    GPS aerial about 12 or you can buy an adapter so you can use your RNS-D one for about the same price
    The diversity aerial adapter will be 20
    Just type RNS-E and the world will be your oyster
    Sep 2003
    Bournemouth
    312
    Got the ebay adapters iso to quadlock and diversity to doublebfakra but still need a smb to fakra adapter and the colour dis cable. The original rns-d has a 26 pin cable from it to the dis in the dash but the rns-e has a 32 pin connector The rns-e is working but no info in the dis and also the unit does not light up when the lights are on
