AH FabricationsSky Insurance
    Dec 2004
    Suffolk, UK
    17
    Unhappy Phatbox install disappointment - help needed
    OK so I got my Phatbox and took the aluminium cover off to give it the smallest size it could be.
    It doesn't fit in either of the top two sections of the glove box but might fit upside down in the lower section. It may be OK the right way up if I manufacture a replacement cover and use industrial velcro.
    The only other option there is to make a Phatbox size hole in the back of the glovebox to take it, which seems a bit drastic and could cause problems at sell on - unless I get a spare glovebox inner to match!!!
    There isn't sufficient clearance under the front seats either as I tried and the storage under the front of those seats but it is the wrong shape to put it in.
    So it looks like carving the back of the glovebox out or a boot install are the only options.
    I really don't want to surface mount it in the boot as I carry lots of guitars, amps and ancilaiiry stuff and it would be in the way or get knocked about.
    Does anyone know if the side panels in the boot come out easily? If so, maybe I could hide it in there. If I had the old A3 still, it could go where the multi CD player lives as there were nice easy to remove panels.
    Maybe I could get a different panel to fit a 2004 A3 with the same 'door' in it as the 2001 A3.
    All assistance and advice appreciated. I need music and I am fed up carrying loads of CDs in the glovebox.
    AARRGGHH!!!!
    scoTTy's Avatar
    Essex, UK
    1,958
    I was fortunate I guess as my B6 S4 has an open back to the glove box and it just wnet straight in.
    I'd open the back of the glove box but only where needed.
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    giblets46's Avatar
    Nov 2006
    156
    Mine is just free in the boot, I carry a lot of hard heavy boxesin the boot every day with work (and drive like a maniac), and not had a problem with it for 2years. So maybe just attached it to the side of the boot, up high somewhere?
    Marc Quinlivan on here has done an EXCELLENT install guide for his phatnoise in the boot, very smart, and lots of pics:
    http://audiretrofit.quinlivan.net/
    Any spelling/ grammatical errors are there purely to annoy!
    A4 2.0TDI (143) S-Line Quartz Grey
