Sky InsuranceEM Tuning
Thread: A6 MMI Options
    Nov 2007
    Ayrshire
    21
    A6 MMI Options
    Hi, I will soon take delivery of an A6 SE with what I believe to be the basic MMI unit (screen embedded in dash, controls in centre consul) with a single CD box in the glove box.
    What upgrade options are available without major surgery?
    Can I fit my Phatbox in place of the CD unit?
    Can I fit my Parrot 3100 easily?
    Any suggestions, tips or tricks greatly appreciated.
    Please check out my old A6 in the classifieds.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Phatbox is not compatible at all. It uses the CD changer interface which doesn't exist in the A6 MMI. You can add either another 6 CD changer with MP3 capability or a Dension gateway 500 and an Ipod or memory stick.
    You can fit your parrot as there is a mute pin on the back of the CD/Radio unit. Not a 100% certain if there is a TEL+/TEL- connection for the speaker at all, I would have to check.
    Nov 2007
    Ayrshire
    21
    The current CD/Radio is a single disc unit, if the MMI does not have a changer interface can I fit a 6 disc unit?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes you can as the MMI uses a daisy chain of fiber optic devices, the spec allows 4 media devices, although Audi only use 2 if them currenty on MMI 2G, so the CD/Radio is one device and the 6 CD is another. It will appear as 7 CD's in the MMI.
    But adding the 6 CD is not as simple as it appears, when installing a new CD changer it will go into antitheft mode, known as Component Protection, this will cuase the CD changer to skip every 2 secs. This has to be cleared by a dealer online to germany.
    Secondly, if you add a 6 CD with MP3 capability, your MMI has to be upto date enough to support the new CD capabilites.
    6 CD changers are as follows
    4E0 035 111 x non MP3 capable
    4E0 035 110 x MP3/CD capable device
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    Won't the A6 will take an RNS-E and then you can keep the Glovebox CD and then you'll have SatNav PLUS the 8Gb of MP3's via the two SD card slots?
    LostBok/BahnStormer77
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No, were talking new shape A6 from 2005 onwards, no RNS-E, only MMI with MOST.
