EM TuningVolks Autos
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Removing Bose Headunit
    Need to take it out, any1 know how... do u need keys 4 it?
    any info would be handy
    cheers
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Yes. You need keys (4 if it's a Symphony Double Din). Best to get genuine Audi ones, as the cheapy ebay ones bend too easily.
    Also, don't pull it out with the keys, as this will damage the clips.
    Remove the glove box, put in the keys then push out the HU from the rear.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Quote Originally Posted by alijames View Post
    Cheers,
    Cheers 4 that
    Now : Cupra R 225
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    As a semi-side issue: I'm pretty sure the head unit is the same wether it's regular / Bose.... the "Bose" part is the speakers (with separate amp and sub), if you just replace the head unit, you'll keep everythign that is Bose.... I replaced my Symphony with a RNS-E and still ahve the Bose amp and speakers...
    edit: the bit I am NOT sure about is wether the Audio pilot (accoustic momnitoring) mic is wired back into the head unit or the Bose amp - I think it's the latter though as I think it's only the Bose that has the cabin audio monitoring kit.
    LostBok/BahnStormer77
