Badger5Sky Insurance
    Apr 2009
    thorpe surrey uk
    22
    rear door speakers
    Hi everyone
    I have a problem with the rear door speakers on my 18T 2003 advant 163 sport.The head unit is the symphony non bose with cd stacker .The rear door speaker are not working as they should as one does not work and the other sounds distorted and clicks and pops.My question is are this speakers off the amp or head unit and has anybody had any sort of similar problem and how to fix
    Many thanks
    Jun 2003
    World of my own
    9,813
    The rears are driven off the sub amp in the boot on the non Bose setup (drivers side cubbyhole). Chances are the amp could be playing up, or the speakers are blown. Easy enough to check. Connect a multimeter set to ohms across the rear connection on the one that doesn't work, and see if you get a circuit reading 4 ohms, or connect a AA battery across the connection and see if the speaker pops. The Bose amps are notorious for dry solder joints but not aware of similar problems with the non Bose amp. Does the sub work OK? (or as OK as it can work!)
    You can also get issues with the door pillar connection on the feed to the speakers, but this mainly affects the fronts.
    I have a spare amp from our Avant which I am happy to send you so you can do a quick swap to see if it cures the issue. Just let me know.
    Alex Turner
    Apr 2009
    thorpe surrey uk
    22
    Thanks Andy Mac will try when I get a chance and will post outcome
