Upgraded stereo, but rubbish radio reception
ajmackie
Cheshire
Website
www.audi-sport.net
Hi
I do believe I read something before about there being a amplifier for the aerial which an after market head unit such as sony can't power.
I have 99 A4 and in my previous 95 A4 I had perfect repcepiton with the same head unit. Can anyone tell me whether I definately need an adaptor for the aerial amplifier and how much it is. I asked in my local car audio shop and they said the aerial power feed output just turns it on off the loom, but this doesn't seem to work!
Any help much appreciated!!
Also has anyone else noticed that you get less bass from a sony cdx-mp40 head unit wired directly to the rear speakers than the standard concert head unit with active rear speakers.
The consensus seems to be that Audi had so many problems with the aerial amp hidden somewhere near the aerial (which was a b*gger to get to) that they started putting the amp inside the HU. This was definately the case on the A3 with the bee-sting as the amp was inside the aerial itself. I guess they did the same on the A4 to make the HU's interchangeable. In which case you'll need the aerial adapter/amp thing, about £14 and needs the flying lead powered off the power antenna lead on the HU.
this works a treat - have just done the same on my 1997 A3
can u just cut into the lead and wire a power to it ?
where can i get one of those gadgets, i will be swapping my HU in my A3 quite soon and would like all bits at hand /ubbthreads/images/graemlins/smile.gif
TIA
Dean
Hiya,
Does anyone know if the same applies to the Navi Plus unit?
FM works fine, but no MW reception at all! I've checked the aerial at the back of the HU, and all seems fine.
Sorry if I've hijacked the post
It will be the same for any aftermarket equipment that uses the factory aerial.
The adapter amp is readily available from caraudiodirect or incar express or even Halfords depots sell them.
cheers for the link gilbo ive been lookin for one of theese for a while! and a pretty cheap site too.
/ubbthreads/images/graemlins/beerchug.gif
cheers tony
Cool!
I'll post my comments as soon as I get it fitted.
It'll be interesting to see what difference it makes to the Navi Pllus unit, as it is an Audi product. At less than £15 it's worth the risk - I can alsways flog it on ebay if it doesn't make any difference for me!
