Monster MotorsportBadger5
    Nov 2004
    Surrey
    26
    Help Fitting DAB to RNS-E
    I have a 2004 allroad. It has RNS-E, TV, OEM Bluetooth conversion and CD changer. I have bought a Pure Highway which transmits DAB through FM. Once I had an external aerial fitted, it is brilliant...unless you live in London, then there are no free frequencies on FM and it is useless. So, guess where we live. It has a 3.5mm line out which would completely cure the problem, so does anyone know how I can connect it whilst leaving everything else working please? I know I don't need a CD changer as I have SD card slots, but my wife likes the CD changer so it is staying!! I feel there must be something to split the CD input, showing it on the Aux source along with the TV and MP3 and CD options?
    Oct 2003
    up north...
    767
    the oem tv used to have 2 auxillary imputs, selectable from the oem head unit - you could connect the dab audio to the tv aux input - select tv then use the tv controls to select aux 1
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    27,126
    Just use the AUX in if you want just the audio mate & I just use the external DAB unit for changing stations, 12 mod if you want proper socket, I fitted mine under the handbrake as with L-shaped jack fits perfect.
