Volks AutosMonster Motorsport
Results 1 to 9 of 9
    Feb 2009
    bypassing stock amp
    hi
    i have a 2003 a4 b6 , ive fitted a new alpine headunit, and have run new speaker cable to the boot , ive also managed to locate the standard amp,
    now the amp has 1 block of wires coming out of it, all i need to know is what wires i need from the bundle of cable from the amp, to connect to my new wire i have run down to the boot.
    Feb 2009
    any ideas guys, just need to know what wires run the rear speakers
    Jun 2003
    World of my own
    9,813
    Here you go:
    Alex Turner
    Feb 2009
    andymac to the recue, cheers mate thats just what i needed,
    so i take it, all i need is
    brown/red
    brown/green
    red/yellow
    brown/yellow
    snip them wires and conect them up to my new cable ive run down, and then just leave the plug unconected from the amp ???
    Jun 2003
    World of my own
    9,813
    Yes they're the ones. You can leave the plug unconnected, but this will disconnect the sub (if you have one). If you still want to run the amp for just the sub then tape up the cut wires coming from the connector, so they don't short on each other or the chassis. Also switch the RCA input at the head unit from the rear RCA's to the sub pre-outs, then jack the level up on the sub control (if you have one) as the sub will be very quiet compared to the cabin speakers running off the HU.
    Alex Turner
    Feb 2009
    i have a infinity basslink t in the back so i wont need the stock sub
    thanks for your help andy, i will post some pics of my setup
    Mar 2009
    Question
    Hi, what trim needs to be removed to get to the standard amp ? Had a look today but dont want to damage anything !
    Jun 2003
    World of my own
    9,813
    You should be able to get to the amp and connector just through the cubbyhole, otherwise you need to remove the boot lip trim, cargo anchors and finally the rear boot trim.
    Alex Turner
    Mar 2009
    Thank you Andy, have now found the amp and will be doing this - '' If you still want to run the amp for just the sub then tape up the cut wires coming from the connector, so they don't short on each other or the chassis. Also switch the RCA input at the head unit from the rear RCA's to the sub pre-outs, then jack the level up on the sub control (if you have one) as the sub will be very quiet compared to the cabin speakers running off the HU. ''
