Monster MotorsportVolks Autos
Results 1 to 7 of 7
    k3v
    Feb 2009
    14
    Removing headunit
    I have an A3 '04' plate. I want to remove the standard head unit. What is the best way to do it?
    thanks
    Jun 2003
    World of my own
    9,813
    You need the removal keys, either from Audi or Halfrauds, or if you have a friendly dealer they might just pull it for you.
    Alex Turner
    k3v
    Feb 2009
    14
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    no they wont you need the audi or merc look like a little knife one edge flat and the other curves to a point . flat edge to the outer sides when removing
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    k3v
    Feb 2009
    14
    Quote Originally Posted by andybnwc View Post
    Do you meen like these?
    http://caraudiosecurity.com/shop/pro..._id/10769.html
    Its just this shop is alot closer than halfords to go to.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    k3v
    yes there the ones mate
    LOTS DONE, LOTS SPENT !!!!
    k3v
    Feb 2009
    14
    cheers for your help, all done now
