AH FabricationsEM Tuning
Results 1 to 7 of 7
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    How to wire up 2 subs to one amp?
    How to wire up this http://www.caraudiodiscount.com/kac-...r-p-11555.html
    amp spec is
    Rated power (4 ohm, 20 ~ 200 Hz, 0.5% THD) @ 14,4V : 300W RMS
    Rated power (2 ohm, 100Hz, 0,9% THD) @ 14,4V : 550W RMS
    Maximum output power @ 14,4V : 1100W
    to 2 seperate subs 1 x 10" 500 rms and 1 x 12" 300w rms Alpine both in seperate enclosures
    will this work? or sound cr*p?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Jun 2003
    World of my own
    9,813
    If both the subs are single voice coil 4 ohm impedance then just wire them in parallel to the mono amp, which will give you a 2 ohm load and thus 550wrms shared between the 2 which is the most efficient use of the available power. To wire them in parallel connect the +ve's from both subs to the +ve output on the amp, and both -ve's to the -ve output fom the amp.
    If the subs are dual voice coil then it'll depend on te impedance rating as to ho to wire them. i.e. if the 10" sub is dual 4 ohm then I'd personally ditch the 12" one and wire the 2 VC's on the 10" in parallel and drive it on its own as a 2ohm load.
    Alex Turner
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Thanks AndyMac damn i think they are dual the 10" is a type r and the 12" type s.
    ive just wired up the 12" for the 1st time and i like the deep sound of the 12" dying to try out what they both sound like but waiting for your advice. the type r 10" is a better made sub, but doesnt sound as deep.
    ive had the 10" for a while and managed to pick up the 12" for a price i couldnt refuse
    i dont drive the sound up too hard for too long at all. just hope there is a way to work something out.
    thanks again
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    ^^^ bump
    Jun 2003
    World of my own
    9,813
    As already said wiring them in parallel is the only option, although obviously you'll have no control of the settings for each individual sub and as they are different models this is not ideal.
    Alex Turner
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Thanks Andy for your reply as long as i cant do any damage as my subs are dual voice coil, im interested to see what it sounds like.
    Jun 2003
    World of my own
    9,813
    If they are dual voice coil then you need to let us know what impedance (per VC) as you could damage the amp if not done correctly.
    Alex Turner
