EM TuningAH Fabrications
    Jan 2009
    Wick,pretty much as far north of britain u can go
    Help with new HU,amp
    Hi,have recently changed my concert HU to an aftermarket unit in my 2003 53plate a4.I purchesed the PC9-401 adaptor pluged it all in and pluged the rca cables on the adaptor into the rca connections on back of my HU.But have no sound out of the back speakers at all.Im i right in thinking you need a switched supply to the amp is that why you are giving the blue cable with the adaptor.Would a permanent feed at the amp do for just now or would it drain the battery as i only have the HU on the permanent feed just now until i get round to getting the ignition switch wired up and also i plugged the ariel into the back of the new head unit but am not getting a good reception.but there is one more cable spare that came out of the original HU a small kind of green coulourd push in connection could that have any thing to do with it.have done a few searches but need someone to put me straight as i am an electrician but car electrics baffle the hell out of me any help would be gratefullf appreciated thanks
    Dec 2006
    barnsley
    927
    the blue wire is "remote turn on"
    this powers up the amp when 12 volts is sent down the cable
    when it loses 12 volts the amp will shut down
    i wouldnt advise connecting the amp to a permanent feed as it will drain the battery
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jan 2009
    thanks thats what i thought so ill just make do with no back speakers until i get the ignition wire conected any thoughts on the radio
