AH FabricationsEM Tuning
    Jan 2009
    Parrot bluetooth car kit
    Hi, been using these forums as a guest for a while now to get some info on purchasing a bluetooth car kit. Anyway after seeing on here how fairly easily it could be installed I opted for a Parrot (CK3000)
    Ive got an 58 plate A3 sport - facelift version (not sure what the exact radio model is but if someone tells me how to find it I will) and the ISO plugs wont fit? I did read in another thread on a Parrot that they fit no problem but this certainly isnt the case with mine? Have they changed on the newer version?
    I took a couple of pictures just in case I havent described it too well:
    Audi connector
    Parrot lead (1 0f 2)
    Also, this is the side of the Audi connector. How do you get it out? Just nip the 2 little plastic clips together? I couldnt get it to budge, although I was cautious not to snap anything.
    Thanks for the help, Mark
    Jan 2004
    York
    1,653
    Thats a quad lock I believe. You'll need a wiring adaptor for you head unit.
    MY15 8V S3 Sportback with options
    Jan 2009
    I suspected as much when I saw it. Anyone got a link to the lead I need? There are loads came up when Ive searched on google and not sure on the exact one I need.
    Jan 2009
    Anyone?
