Sky InsuranceBadger5
    Toxik-Signal's Avatar
    Andy
    Oct 2006
    Nottingham
    357
    What amp to easily power 2x10" subs?
    Hi all, just a quick question really as I don't know much about sound systems.
    I've got 2 x 10" subs in a sealed box, which are currently being powered by this amp:
    http://www.theloudest.co.uk/?section...&product_id=76
    The 2 subs are these:
    http://www.xplodsony.com/xplod/subwoofers/XS-L104P5B
    They seem to work 'ok' but I noticed that when I disconnect one of the subs, the quality of bass I get out of the remaining sub is better [it sounds more bassy / less distorted / more powerful].
    I read a bit on Class D amplifiers and it sounds like I need a Class D instead of what I've got already as I only need to power the 2 subs from an amp].
    Can someone advise me as to what type of amp I should buy please?
    Thanks!
    Andy
    Oct 2006
    Nottingham
    357
    Bump! :]
    Jan 2009
    Its been quite a while since Ive had a half decent install in my car but one thing I will say is there is absolutely no way that you can get 1500w out of an amp that costs 120! That will be the peak power and the RMS will be a fraction of that power output, then add on top that youve probably doubled the ohms and therefore halfed the output the subs wont be getting enough juice basically.
    Go for a dedicated car audio brand, JL, Kicker even Alpine will all give you much better power and quality.
    Just had a quick look and something like this should give you a bit more in all departments http://www.caraudiodirect.co.uk/kick...vmgmeodev4loa3
    Dec 2006
    barnsley
    1,012
    that amps isnt one i would reccomend but it will do what is needed
    the class d amps are more efficient than normal a/b
    but you dont need anything like that amount of power to run those subs properly
    they would be fine on the end of the amp you allready have
    in reality the amp depending on how you have connected the sub up to it
    will be putting out somewhere in the region of 500 wrms total
    which is ample for those subs
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
